Salta al contenuto principale
Beats Studio 2.0 Wireless Left Interior Side Panel Replacement
Cosa ti serve
  1. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement, Left Interior Side Panel: passo 1, immagine 1 di 1
    • Use metal spudger to pry away ear cushion.
  2. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 2, immagine 1 di 1
    • Remove ear cushion from headphones (attached by adhesive).
  3. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 3, immagine 1 di 1
    • Remove two screws from the metal hinge using a Phillips head screwdriver to allow more motion from the speaker housing and more accessibility.
  4. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 4, immagine 1 di 1
    • Remove five screws using a Phillips head screwdriver from speaker housing.
  5. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 5, immagine 1 di 1
    • Pull speaker away to access second secondary housing.
    • Be careful not to stress wires and break solder points.
  6. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 6, immagine 1 di 2 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 6, immagine 2 di 2
    • Raise center cover.
    • Remove screw from center of housing.
  7. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 7, immagine 1 di 1
    • Pull secondary housing away gently being careful not to damage the wires.
  8. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 8, immagine 1 di 1
    • Remove four screws using a Phillips head screwdriver to remove the third housing.
  9. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 9, immagine 1 di 3 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 9, immagine 2 di 3 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 9, immagine 3 di 3
    • Disconnect wires gently.
    • Be gentle with the wires ensuring to pull them through with care to eliminate possible shortages.
  10. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 10, immagine 1 di 3 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 10, immagine 2 di 3 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 10, immagine 3 di 3
    • Pass wire through new housing and reconnect wires.
  11. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 11, immagine 1 di 1
    • Snap housing into place.
    how did you disconnect the red & black wires?
    I was able to disconnect other two rather easily but cannot seem disconnect 3rd one.
    thanks!
    hong - Replica
Conclusione
Antares Cam
Membro da: 02/27/18
235 Reputazione
1 Guida realizzata
colby and cameron Membro di colby and cameron
Community
2 Membri
1 Guida realizzata
2 Commenti
Thank you for your tutorial!
Jonathan Concepcion - Replica
appreciate it, fixed both side panels on my beats
mridha31 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 23
Tutti i Tempi: 5,602
