Salta al contenuto principale
Introduzione
The casing and structure of Beats by Dre Studio 2.0 over-ear headphones directly influence their sound quality. When the interior side panel is compromised, a proper seal (to one's ears) is not achievable, and ultimately sound quality is severely lessened. This guide will provide thorough instructions on how to replace the interior side paneling and restore optimal sound quality.
  1. Use metal spudger to pry away ear cushion.
    • Use metal spudger to pry away ear cushion.
  2. Remove ear cushion from headphones (attached by adhesive).
    • Remove ear cushion from headphones (attached by adhesive).
  3. Remove two screws from the metal hinge using a Phillips head screwdriver to allow more motion from the speaker housing and more accessibility.
    • Remove two screws from the metal hinge using a Phillips head screwdriver to allow more motion from the speaker housing and more accessibility.
  4. Remove five screws using a Phillips head screwdriver from speaker housing.
    • Remove five screws using a Phillips head screwdriver from speaker housing.
  5. Pull speaker away to access second secondary housing.
    • Pull speaker away to access second secondary housing.
    • Be careful not to stress wires and break solder points.
  6. Raise center cover. Remove screw from center of housing.
    • Raise center cover.
    • Remove screw from center of housing.
  7. Pull secondary housing away gently being careful not to damage the wires.
    • Pull secondary housing away gently being careful not to damage the wires.
  8. Remove four screws using a Phillips head screwdriver to remove the third housing.
    • Remove four screws using a Phillips head screwdriver to remove the third housing.
  9. Disconnect wires gently. Be gentle with the wires ensuring to pull them through with care to eliminate possible shortages. Be gentle with the wires ensuring to pull them through with care to eliminate possible shortages.
    • Disconnect wires gently.
    • Be gentle with the wires ensuring to pull them through with care to eliminate possible shortages.
  10. Pass wire through new housing and reconnect wires. Pass wire through new housing and reconnect wires. Pass wire through new housing and reconnect wires.
    • Pass wire through new housing and reconnect wires.
  11. Snap housing into place.
    • Snap housing into place.
Conclusione
Antares Cam
Membro da: 27/02/2018
228 Reputazione
1 Guida realizzata
colby and cameron Membro di colby and cameron
Community
2 Membri
1 Guida realizzata
Thank you for your tutorial!
Jonathan Concepcion - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 91
Tutti i Tempi: 2,088
