Salta al contenuto principale
Beats Solo 3 Headband Replacement
Cosa ti serve
  1. Beats Solo 3 Headband Replacement, Headband: passo 1, immagine 1 di 3 Beats Solo 3 Headband Replacement, Headband: passo 1, immagine 2 di 3 Beats Solo 3 Headband Replacement, Headband: passo 1, immagine 3 di 3
    • Carefully partially remove the headband cushion cover. Be careful not to rip the two headband eyelets just above the screws on each end of the headband.
  2. Beats Solo 3 Headband Replacement: passo 2, immagine 1 di 2 Beats Solo 3 Headband Replacement: passo 2, immagine 2 di 2
    • With the main part of the cover off, pull the head band cover up and out of the metal headband ends, exposing the screws underneath.
  3. Beats Solo 3 Headband Replacement: passo 3, immagine 1 di 3 Beats Solo 3 Headband Replacement: passo 3, immagine 2 di 3 Beats Solo 3 Headband Replacement: passo 3, immagine 3 di 3
    • Unscrew all four 1.4 mm screws on the right and left ends on the underside of the headband using a T5 Torx screwdriver.
  4. Beats Solo 3 Headband Replacement: passo 4, immagine 1 di 1
    • Pull the metal headband end out from the headband slightly, and disconnect the rubber band from the hook.
  5. Beats Solo 3 Headband Replacement: passo 5, immagine 1 di 2 Beats Solo 3 Headband Replacement: passo 5, immagine 2 di 2
    • Remove the inner headband by gently prying the edges and corners.
  6. Beats Solo 3 Headband Replacement: passo 6, immagine 1 di 1
    • Carefully peel up the glued wire in the headband.
  7. Beats Solo 3 Headband Replacement: passo 7, immagine 1 di 1
    • Pull the headband out of the slots gently.
  8. Beats Solo 3 Headband Replacement: passo 8, immagine 1 di 1
    • Put the new headband into the slots carefully.
Conclusione
Altre 4 persone hanno completato questa guida.
Joseph Konadu
Membro da: 03/24/21
211 Reputazione
1 Guida realizzata
2 Commenti
help when i was putting on the new headband the snap on middle parts fell out and i cant put them back in (the metal connection parts)
koro - Replica
same it happen to me as well
Bardo -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 197
Tutti i Tempi: 11,386
