Salta al contenuto principale
Beats Solo 2 Wireless Power Button Replacement
Cosa ti serve
  1. Beats Solo 2 Wireless Power Button Replacement, Power Button: passo 1, immagine 1 di 3 Beats Solo 2 Wireless Power Button Replacement, Power Button: passo 1, immagine 2 di 3 Beats Solo 2 Wireless Power Button Replacement, Power Button: passo 1, immagine 3 di 3
    • Insert an opening pick in the seam between the right outer speaker casing and the speaker housing.
    • Slide the pick around the perimeter of the casing until the casing releases entirely from the speaker housing.
    • If you encounter any resistance, continue to pry along any spots where the seam is still close together.
    • Failure to loosen the seams may result in the piece breaking partially or completely during removal.
  2. Beats Solo 2 Wireless Power Button Replacement: passo 2, immagine 1 di 2 Beats Solo 2 Wireless Power Button Replacement: passo 2, immagine 2 di 2
    • Remove the right outer casing.
  3. Beats Solo 2 Wireless Power Button Replacement: passo 3, immagine 1 di 3 Beats Solo 2 Wireless Power Button Replacement: passo 3, immagine 2 di 3 Beats Solo 2 Wireless Power Button Replacement: passo 3, immagine 3 di 3
    • Use a Phillips screwdriver to remove the 2.8 mm screw on the outer shell of the headphones.
  4. Beats Solo 2 Wireless Power Button Replacement: passo 4, immagine 1 di 1
    • Remove the power button with your hand or a spudger by prying out the end that is still attached.
    • Beware of the sponge piece when putting the power button assembly back together.
Conclusione
Victor Diuno
Membro da: 04/02/24
130 Reputazione
1 Guida realizzata
IUPUI, Team 2-1, Harley Spring 2024 Membro di IUPUI, Team 2-1, Harley Spring 2024
IUPUI-HARLEY-S24S2G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 94
