Salta al contenuto principale
Beats Solo 2 Wireless Battery Replacement
Cosa ti serve
  1. Beats Solo 2 Wireless Battery Replacement, Battery: passo 1, immagine 1 di 3 Beats Solo 2 Wireless Battery Replacement, Battery: passo 1, immagine 2 di 3 Beats Solo 2 Wireless Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Insert an opening pick in the seam between the right outer speaker casing and the speaker housing.
    • Slide the pick around the perimeter of the casing until the casing releases entirely from the speaker housing.
    • Failure to loosen the seams may result in the piece breaking partially or completely during removal.
  2. Beats Solo 2 Wireless Battery Replacement: passo 2, immagine 1 di 3 Beats Solo 2 Wireless Battery Replacement: passo 2, immagine 2 di 3 Beats Solo 2 Wireless Battery Replacement: passo 2, immagine 3 di 3
    • Remove the right outer speaker casing.
  3. Beats Solo 2 Wireless Battery Replacement: passo 3, immagine 1 di 3 Beats Solo 2 Wireless Battery Replacement: passo 3, immagine 2 di 3 Beats Solo 2 Wireless Battery Replacement: passo 3, immagine 3 di 3
    • Use tweezers to disconnect the battery connector from the circuit board.
    • Do not pull on the wires.
  4. Beats Solo 2 Wireless Battery Replacement: passo 4, immagine 1 di 3 Beats Solo 2 Wireless Battery Replacement: passo 4, immagine 2 di 3 Beats Solo 2 Wireless Battery Replacement: passo 4, immagine 3 di 3
    • Use an opening pick to gently pry up the battery.
    • The battery is secured in the housing with adhesive. You can apply some high-concentration alcohol beneath the battery to help loosen the adhesive.
    • Avoid bending or puncturing the battery.
  5. Beats Solo 2 Wireless Battery Replacement: passo 5, immagine 1 di 1
    • Lift the battery up and out of the chassis.
Conclusione
Cooper Truong
Membro da: 04/02/24
277 Reputazione
2 Guide realizzate
IUPUI, Team 2-1, Harley Spring 2024 Membro di IUPUI, Team 2-1, Harley Spring 2024
IUPUI-HARLEY-S24S2G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 13
Tutti i Tempi: 84
