Salta al contenuto principale
Beats Pill XL Battery Replacement
Cosa ti serve
  1. Beats Pill XL Battery Replacement, Case: passo 1, immagine 1 di 2 Beats Pill XL Battery Replacement, Case: passo 1, immagine 2 di 2
    • Using a plastic opening tool, pry the casing from the rest of the device.
    • Pry all the way around the edge and then pull apart.
    • It should be relatively easy, to pull apart. Don't be afraid to apply a necessary force.
  2. Beats Pill XL Battery Replacement: passo 2, immagine 1 di 1
    • Using your thumb, remove the 8 rubber plugs in order to get to the screws.
    • Simply rub them towards the speakers and they will slide out enough to grip the edge and pull them out.
    • In the picture provided, we labeled four of them on one side of the Beats Pill XL. The other four are symmetrical to these four on the other side of the device.
  3. Beats Pill XL Battery Replacement: passo 3, immagine 1 di 2 Beats Pill XL Battery Replacement: passo 3, immagine 2 di 2
    • Using a Phillips #2 screwdriver, remove the 8 (10mm maxi-loc Phillips #2) screws that hold the casing together.
  4. Beats Pill XL Battery Replacement: passo 4, immagine 1 di 2 Beats Pill XL Battery Replacement: passo 4, immagine 2 di 2
    • Pull apart the front casing from the back casing, slowly. Try to avoid any tension on any of the connected cables.
    • Separate at a slow constant force to avoid damage to the ribbon cables.
  5. Beats Pill XL Battery Replacement: passo 5, immagine 1 di 2 Beats Pill XL Battery Replacement: passo 5, immagine 2 di 2
    • Gently pull on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
    • Never pull the cables by the cord, as this could cause damage to the cables and/or motherboard. Always disconnect the cables from the base by the motherboard.
  6. Beats Pill XL Battery Replacement: passo 6, immagine 1 di 2 Beats Pill XL Battery Replacement: passo 6, immagine 2 di 2
    • Using your thumb and index finger, pull upwards on the base of the the power cable to remove it from the motherboard.
    • Even though there are two batteries, there is only one cable connecting the two to the motherboard.
  7. Beats Pill XL Battery Replacement, Battery: passo 7, immagine 1 di 3 Beats Pill XL Battery Replacement, Battery: passo 7, immagine 2 di 3 Beats Pill XL Battery Replacement, Battery: passo 7, immagine 3 di 3
    • Using a Phillips #2 screwdriver, remove the 8 (11mm pan head Phillips #2) screws holding down the the X-clamps.
    • Remove the X-clamps by simply lifting upwards.
    • Save the 8 (11mm pan head Phillips #2) screws for reassembly as these are easy to misplace.
  8. Beats Pill XL Battery Replacement: passo 8, immagine 1 di 2 Beats Pill XL Battery Replacement: passo 8, immagine 2 di 2
    • Gently pull up on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
  9. Beats Pill XL Battery Replacement: passo 9, immagine 1 di 2 Beats Pill XL Battery Replacement: passo 9, immagine 2 di 2
    • Remove the padded sticker holding down the ribbon cable to one of the batteries.
    • Use a slow constant force, as ribbon cables are fragile and could tare.
  10. Beats Pill XL Battery Replacement: passo 10, immagine 1 di 2 Beats Pill XL Battery Replacement: passo 10, immagine 2 di 2
    • Lift straight up from the casing to remove each batteries from their tight spaces.
Conclusione
Altre 21 persone hanno completato questa guida.
Nolan
Membro da: 03/11/15
855 Reputazione
2 Guide realizzate
7 Commenti
como saber se o problema da minha caixa e a bateria, ela nao esta carregando nem liga, a bateria porem nao esta dando 12v medicao, uma por sinal esta com carga negativa. no aguardo
marcosallexandre - Replica
Where can i buy these replacement batteries?
Edgar Zuniga - Replica
From here you can find a replacement battery
http://www.witpow.com/shopdvr/product/4/...
lisi -
i think it's better to change a battery than buy a new one. And i was luck to find a replacement battery.lol
Jailene -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 103
Tutti i Tempi: 27,795
