Salta al contenuto principale
Beaded Bracelet Clasp Replacement
Cosa ti serve
  1. Beaded Bracelet Clasp Replacement, Beaded Bracelet Clasp: passo 1, immagine 1 di 1
    • From the left end of the bracelet, string on a crimp bead and one end of the new clasp.
    • Bring the clasp and crimp bead 3 inches from the left end of the string.
  2. Beaded Bracelet Clasp Replacement: passo 2, immagine 1 di 1
    • Loop the left end of the string through the left side of the crimp bead.
  3. Beaded Bracelet Clasp Replacement: passo 3, immagine 1 di 1
    • Push the crimp bead up close to the clasp.
    • Push the crimp bead up as close as you can to the clasp.
  4. Beaded Bracelet Clasp Replacement: passo 4, immagine 1 di 2 Beaded Bracelet Clasp Replacement: passo 4, immagine 2 di 2
    • Use the bead crimp tool to squeeze the crimp bead shut.
    • Use scissors to cut off excess string.
  5. Beaded Bracelet Clasp Replacement: passo 5, immagine 1 di 1
    • Bead the bracelet from the right end.
  6. Beaded Bracelet Clasp Replacement: passo 6, immagine 1 di 1
    • After all beads are on, string on a crimp bead and then the other end of the new clasp.
  7. Beaded Bracelet Clasp Replacement: passo 7, immagine 1 di 1
    • Loop the right end of the string through the right side of the crimp bead.
  8. Beaded Bracelet Clasp Replacement: passo 8, immagine 1 di 1
    • Pull on the string to tighten the bracelet.
    • You do not want the beads spread out.
  9. Beaded Bracelet Clasp Replacement: passo 9, immagine 1 di 2 Beaded Bracelet Clasp Replacement: passo 9, immagine 2 di 2
Conclusione
Altre 2 persone hanno completato questa guida.
Kelly
Membro da: 03/22/16
182 Reputazione
1 Guida realizzata
2 Commenti
Awesome!! Its very beautiful [|bracelets] each step make this bracelets so easy. Thank you!! Keep it up
daniel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 39
Tutti i Tempi: 2,457
