Salta al contenuto principale
Bazic 3003 Battery Replacement
Cosa ti serve
  1. Bazic 3003 Battery Replacement, Bazic Calculator: passo 1, immagine 1 di 1
    • Press the "OFF" button on your Bazic 3003 calculator.
    • Make sure it is powered off before you begin the repair.
  2. Bazic 3003 Battery Replacement: passo 2, immagine 1 di 1
    • Turn your calculator over so the back is facing up.
  3. Bazic 3003 Battery Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the 1.0 mm screw from the battery compartment.
  4. Bazic 3003 Battery Replacement: passo 4, immagine 1 di 1
    • Only one button battery is needed for the calculator to function but you can add one or two.
    • Use your fingers or a plastic spudger to remove the battery from the calculator.
    • Insert the new button battery into the slot and push it into place.
  5. Bazic 3003 Battery Replacement: passo 5, immagine 1 di 1
    • Replace the battery door.
    • Use a Phillips #0 screwdriver to replace the screw and secure the battery door.
  6. Bazic 3003 Battery Replacement: passo 6, immagine 1 di 1
    • Push the "On" button on your calculator and check if the buttons work and function properly.
Conclusione
Bryan Reyes
Membro da: 03/04/25
136 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 48
Tutti i Tempi: 370
