Introduzione
I am providing a proposal to replace and fix the current battery in my Asus Q524U personal computer. I have only owned this computer for a relatively short period of time, although the battery has already gone bad due to continuous overcharging and must be replaced. I intend to produce a comprehensive guide that will list all required tools/parts to complete the project along with detailed steps explaining the entire process. This will be an easy to follow guide that will help people replace their old computer battery for less money and extend their laptops lifespan that much longer.
Required Equipment: Torx T5 screwdriver; #00 Philips screwdriver; Opening/prying tool; new computer battery.
Cosa ti serve
Remove all 10 screws from the backplate of the computer using a Torx T5 screwdriver.
Pull lightly on the blue tabs until the silver bridge is safely free.
Once the bridge is removed the battery is then accessible.
Get a #00 Philips head screwdriver ready for use.
Carefully remove the #00 Philips screws to release the battery from the computer.
Carefully pull up on the connection to safely disconnect the battery.
Furthermore, this is a comprehensive guide for a battery replacement on an Asus Q524U personal computer. To reassemble your device, please follow these instructions in reverse order.
Altre 3 persone hanno completato questa guida.
3 Commenti
Thanks.
How long a battery should last?
And how long daily without charging?
I'm sorry but i have never had a laptop in my life.
I'll appreciate your help.
Hello I want to ask. I’m trying to replace the battery and im at the part with the blue strip for the Silver bridge part is out how do I put it back on?
