Salta al contenuto principale
Batteries in Nikon Coolpix 4600 Replacement
Cosa ti serve
  1. Batteries in Nikon Coolpix 4600 Replacement, Batteries: passo 1, immagine 1 di 1
    • Locate the battery compartment on the bottom right of the camera.
  2. Batteries in Nikon Coolpix 4600 Replacement: passo 2, immagine 1 di 2 Batteries in Nikon Coolpix 4600 Replacement: passo 2, immagine 2 di 2
    • While holding the camera with the lens facing toward you, slide the lock button to the right and pull the battery door towards you. The battery door should pop open.
    • If the door does not pop open, gently lift the door using your finger.
  3. Batteries in Nikon Coolpix 4600 Replacement: passo 3, immagine 1 di 1
    • Remove the dead batteries. The easiest way to do this is by turning the camera right side up and gently tapping the lens side of the camera against your hand until they fall out. If this does not work, you can simply pull them out.
  4. Batteries in Nikon Coolpix 4600 Replacement: passo 4, immagine 1 di 1
    • Insert fresh AA batteries into the compartment as demonstrated in the picture to the left. The orientation of the batteries is important to ensure the camera works properly.
    • Close the battery door.
    • Remember to slide the switch back into the lock position.
Conclusione
Reassembly of the camera is the final step in the guide.
Richard
Membro da: 04/19/12
9 Reputazione
1 Guida realizzata
Cal Poly, Team 9-43, Regan Spring 2012 Membro di Cal Poly, Team 9-43, Regan Spring 2012
CPSU-REGAN-S12S9G43
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 55
Tutti i Tempi: 3,504
