Salta al contenuto principale
Bathtub Drain Stopper Replacement
  1. Bathtub Drain Stopper Replacement, Bathtub drain stopper: passo 1, immagine 1 di 1
    • You can find a new drain cover at your local Home Depot; I purchased the Danco EZ Drain Cover. This package includes the EZ Drain Cover and two gaskets.
  2. Bathtub Drain Stopper Replacement: passo 2, immagine 1 di 1
    • Remove the old stopper from the drain.
  3. Bathtub Drain Stopper Replacement: passo 3, immagine 1 di 3 Bathtub Drain Stopper Replacement: passo 3, immagine 2 di 3 Bathtub Drain Stopper Replacement: passo 3, immagine 3 di 3
    • The gaskets come in two sizes, large and small. To determine which is the correct size, position the gasket into the groove of the stopper. The flange side should be in an upright position.
    • Insert the stopper with the gasket in the drain.
    • You may have to try both gaskets to ensure the best fit. If it is too loose, water may leak through.
  4. Bathtub Drain Stopper Replacement: passo 4, immagine 1 di 1
    • You may additionally use plumber's putty to seal the stopper if the gasket does not fit securely. To use the plumber's putty, apply it around the under side of the stopper rim. After it is applied, insert the stopper into the drain and press into place.
  5. Bathtub Drain Stopper Replacement: passo 5, immagine 1 di 1
    • Test the stopper by closing the drain and filling the tub with water. Press down on top of the stopper to close the drain.
    • To open the drain and release the water, press down on top of the stopper again.
Conclusione
Fenita
Membro da: 06/09/23
148 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 258
