Salta al contenuto principale
Basis Peak Frame Replacement
Cosa ti serve
  1. Basis Peak Frame Replacement, Frame: passo 1, immagine 1 di 1
    • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
    • Maintain this orientation to follow the guide.
  2. Basis Peak Frame Replacement: passo 2, immagine 1 di 2 Basis Peak Frame Replacement: passo 2, immagine 2 di 2
    • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
  3. Basis Peak Frame Replacement: passo 3, immagine 1 di 1
    • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
  4. Basis Peak Frame Replacement: passo 4, immagine 1 di 1
    • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
    • The clips have small lips that you can put the spudger under to get more leverage.
    • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 176
