Introduzione
This guide gives you the information you need to replace the battery on the Basis Peak product. Each step is shown with pictures to make sure you won't get lost through your work. Its quite simple to get through especially with the helpful guidance provided. There's no tricks and the product can only be dissemble through this one way.
Cosa ti serve
Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
Remove the right side ribbon cable by pulling it off with your fingers.
