Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Prerequisite Only
Parti
Nessuna parte specificata.
  1. Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
    • Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
    • Use a screwdriver to remove all four 11mm Phillips #0 screws.
  2. Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary. Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
    • Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
    • Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
    • The spudger is designed to make this step easier.
Conclusione
Han Shih
Membro da: 29/09/2016
343 Reputazione
4 Guide realizzate
IUPUI, Team 3-3, Harley Fall 2016 Membro di IUPUI, Team 3-3, Harley Fall 2016
IUPUI-HARLEY-F16S3G3
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 59
