Salta al contenuto principale
Barnes And Noble Nook Glowlight 3 Screen Replacement
Cosa ti serve
  1. Barnes And Noble Nook Glowlight 3 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • This is the Nook Glowlight 3. It features an eink display with a resolution of 300 ppi. The display is also Touchscreen. It comes with 8GB of Storage and the Total User Available Memory is 6.5 GB. It is also wifi compatible
  2. Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 2, immagine 1 di 2 Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 2, immagine 2 di 2
    • First Grab Your Jimmy or any other thin wedge tool and slide it along the edge of the device where the two halves meet.
    • Push firmly until the Jimmy gets wedged into the crack. Then rotate the Jimmy while sliding it down to separate the clips
    • Do This all around the device until the device is able to be split into two halves.
  3. Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 3, immagine 1 di 2 Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 3, immagine 2 di 2
    • When both of the halves are able to be separated move the back cover aside.
    • (To Reassemble push down on the back cover)
  4. Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 4, immagine 1 di 1
    • Remove the screws marked in red
  5. Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 5, immagine 1 di 3 Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 5, immagine 2 di 3 Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 5, immagine 3 di 3
    • Disconnect the battery with a flick of the spudger.
  6. Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 6, immagine 1 di 1
    • Tip: Before removing screws draw an outline of the device and place the screws where they are located on the device.
  7. Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 7, immagine 1 di 3 Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 7, immagine 2 di 3 Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 7, immagine 3 di 3
    • On both sides, there are two straight and skinny button panels. These control the side up/down buttons. Please disconnect both of these ribbon cables.
  8. Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 8, immagine 1 di 3 Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 8, immagine 2 di 3 Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 8, immagine 3 di 3
    • Now disconnect the display ribbon cables. ( one is hidden )
  9. Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 9, immagine 1 di 3 Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 9, immagine 2 di 3 Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 9, immagine 3 di 3
    • Now lift the logic board
  10. Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 10, immagine 1 di 3 Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 10, immagine 2 di 3 Barnes And Noble Nook Glowlight 3 Screen Replacement: passo 10, immagine 3 di 3
    • Now remove the battery by sliding a spudger underneath the battery and breaking the adhesive.
Conclusione
Joan Lee
Membro da: 12/09/19
463 Reputazione
2 Guide realizzate
Un commento
I’m afraid you did not get to include how the screen is disassembled.
Ian Van Giesen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 316
