Salta al contenuto principale
Balystik SMR200 HPA Regulator Disassembly and Cleaning
  1. Balystik SMR200 HPA Regulator Disassembly and Cleaning, Disassembly: passo 1, immagine 1 di 3 Balystik SMR200 HPA Regulator Disassembly and Cleaning, Disassembly: passo 1, immagine 2 di 3 Balystik SMR200 HPA Regulator Disassembly and Cleaning, Disassembly: passo 1, immagine 3 di 3
    • Turn your regulator upside down and use needle nose pliers to unscrew the bottom plate by turning it anticlockwise.
    • Be careful not to lose the parts that will fall out. They are not under pressure!
  2. Balystik SMR200 HPA Regulator Disassembly and Cleaning, Unscrew: passo 2, immagine 1 di 3 Balystik SMR200 HPA Regulator Disassembly and Cleaning, Unscrew: passo 2, immagine 2 di 3 Balystik SMR200 HPA Regulator Disassembly and Cleaning, Unscrew: passo 2, immagine 3 di 3
    • Remove the two Hex screws that lock the two parts of the regulator.
    • Remove the screw that is used to regulate the pressure.
  3. Balystik SMR200 HPA Regulator Disassembly and Cleaning, Separate the regulator: passo 3, immagine 1 di 1
    • Unscrew the bottom part from the regulator by turning it anticlockwise.
    • It is not under pressure.
    • Be careful not to lose any parts that may fall out. Especially the small O-ring.
  4. Balystik SMR200 HPA Regulator Disassembly and Cleaning, Cleaning and relubing.: passo 4, immagine 1 di 2 Balystik SMR200 HPA Regulator Disassembly and Cleaning, Cleaning and relubing.: passo 4, immagine 2 di 2
    • Lift up the tube.
    • Clean all the surfaces, threads and insides with a degreaser and a cloth that does not leave debris. I used medical gauze pads.
    • Use a silicon based lubricant (not petrol based) to lube the O-ring on the tube and the one (small one) from the bottom. There are a total of 2 O-rings in this regulator.
    • Use lubricant only on the O-rings and make sure it does not go or spill anywhere else. Do not spray lubricant directly as it will get vary messy and you do not want it anywhere else, besides on the rubber.
Conclusione
Altre 2 persone hanno completato questa guida.
Simeon Brankov
Membro da: 11/08/20
7.153 Reputazione
54 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 46
Tutti i Tempi: 1,232
