Salta al contenuto principale
Backpack Plastic Buckle Replacement
Cosa ti serve
  1. Backpack Plastic Buckle Replacement, Your buckle breaks but you do not want to take out the stitching to replace it: passo 1, immagine 1 di 1
    • The female side is often sewn in. This makes replacement very difficult. Many packs are discarded for this reason
    Chiedi a FixBot
  2. Backpack Plastic Buckle Replacement, The male side (side with prongs) is easy to replace: passo 2, immagine 1 di 1
    • Slide the old one off the strap and install the new male side. If the belt slips through the new male side too easily, remove it and flip it over before reinstalling it.
    Chiedi a FixBot
  3. Backpack Plastic Buckle Replacement, Install the new female side of the buckle: passo 3, immagine 1 di 1
    • Cut the original plastic buckle off the belt, take the stainless steel rod out of the new buckle, thread it through the belt and tighten
    Chiedi a FixBot
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 66
Tutti i Tempi: 647
