Salta al contenuto principale
Backbone One Right Trigger Replacement
Cosa ti serve
  1. Backbone One Right Trigger Replacement, Remove the screws: passo 1, immagine 1 di 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    Chiedi a FixBot
  2. Backbone One Right Trigger Replacement, Rotate the upper part: passo 2, immagine 1 di 3 Backbone One Right Trigger Replacement, Rotate the upper part: passo 2, immagine 2 di 3 Backbone One Right Trigger Replacement, Rotate the upper part: passo 2, immagine 3 di 3
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
    Chiedi a FixBot
  3. Backbone One Right Trigger Replacement, Remove the protective tape: passo 3, immagine 1 di 3 Backbone One Right Trigger Replacement, Remove the protective tape: passo 3, immagine 2 di 3 Backbone One Right Trigger Replacement, Remove the protective tape: passo 3, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
    Chiedi a FixBot
  4. Backbone One Right Trigger Replacement, Open the interconnect cable ZIF connector: passo 4, immagine 1 di 3 Backbone One Right Trigger Replacement, Open the interconnect cable ZIF connector: passo 4, immagine 2 di 3 Backbone One Right Trigger Replacement, Open the interconnect cable ZIF connector: passo 4, immagine 3 di 3
    • Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
    Chiedi a FixBot
  5. Backbone One Right Trigger Replacement, Disconnect the interconnect cable: passo 5, immagine 1 di 2 Backbone One Right Trigger Replacement, Disconnect the interconnect cable: passo 5, immagine 2 di 2
    • Disconnect the cable by pulling it straight out the ZIF connector.
    Chiedi a FixBot
  6. Backbone One Right Trigger Replacement, Disconnect the phone connector cables: passo 6, immagine 1 di 3 Backbone One Right Trigger Replacement, Disconnect the phone connector cables: passo 6, immagine 2 di 3 Backbone One Right Trigger Replacement, Disconnect the phone connector cables: passo 6, immagine 3 di 3
    • Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
    Chiedi a FixBot
  7. Backbone One Right Trigger Replacement, Separate the upper case: passo 7, immagine 1 di 1
    • Separate the the upper case of the left controller handle.
    Chiedi a FixBot
  8. Backbone One Right Trigger Replacement, Remove the screws: passo 8, immagine 1 di 1
    • Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
    Chiedi a FixBot
  9. Backbone One Right Trigger Replacement, Remove the trigger: passo 9, immagine 1 di 2 Backbone One Right Trigger Replacement, Remove the trigger: passo 9, immagine 2 di 2
    • Remove the trigger.
    Chiedi a FixBot
Conclusione
Opening didn’t go as planned? Answers community for help.
Adriana Zwink
Membro da: 12/18/19
66.875 Reputazione
167 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
25.804 guide realizzate
2Commenti sulla guida
where can I buy a right trigger replacement?
pelony felony - Rispondi Condividi
Ricardo Gazo Rosario - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 16
Ultimi 30 giorni: 75
Tutti i Tempi: 1,739
