Salta al contenuto principale
Backbone One Left Trigger Replacement
Cosa ti serve
  1. Backbone One Left Trigger Replacement, Unfasten the screws: passo 1, immagine 1 di 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Left Trigger Replacement, Rotate the upper cover: passo 2, immagine 1 di 3 Backbone One Left Trigger Replacement, Rotate the upper cover: passo 2, immagine 2 di 3 Backbone One Left Trigger Replacement, Rotate the upper cover: passo 2, immagine 3 di 3
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
  3. Backbone One Left Trigger Replacement, Remove the protective tape: passo 3, immagine 1 di 3 Backbone One Left Trigger Replacement, Remove the protective tape: passo 3, immagine 2 di 3 Backbone One Left Trigger Replacement, Remove the protective tape: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
  4. Backbone One Left Trigger Replacement, Open the ZIF connector: passo 4, immagine 1 di 2 Backbone One Left Trigger Replacement, Open the ZIF connector: passo 4, immagine 2 di 2
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
  5. Backbone One Left Trigger Replacement, Disconnect the interconnect cable: passo 5, immagine 1 di 2 Backbone One Left Trigger Replacement, Disconnect the interconnect cable: passo 5, immagine 2 di 2
    • Use your fingers to disconnect the interconnect cable from its connector.
  6. Backbone One Left Trigger Replacement: passo 6, immagine 1 di 2 Backbone One Left Trigger Replacement: passo 6, immagine 2 di 2
    • Remove the upper half of the left controller assembly.
  7. Backbone One Left Trigger Replacement, Remove the screw: passo 7, immagine 1 di 2 Backbone One Left Trigger Replacement, Remove the screw: passo 7, immagine 2 di 2
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
  8. Backbone One Left Trigger Replacement, Remove the trigger: passo 8, immagine 1 di 2 Backbone One Left Trigger Replacement, Remove the trigger: passo 8, immagine 2 di 2
    • Remove the left trigger.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
Altre 2 persone hanno completato questa guida.
Adriana Zwink
Membro da: 12/18/19
62.088 Reputazione
167 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.648 Guide realizzate
1Commento della guida
Where can I buy the trigger
Zach - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 58
Tutti i Tempi: 3,453
