Salta al contenuto principale
Backbone One Direction Pad Replacement
Cosa ti serve
  1. Backbone One Direction Pad Replacement, Unfasten the screws: passo 1, immagine 1 di 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Direction Pad Replacement, Rotate the upper cover: passo 2, immagine 1 di 3 Backbone One Direction Pad Replacement, Rotate the upper cover: passo 2, immagine 2 di 3 Backbone One Direction Pad Replacement, Rotate the upper cover: passo 2, immagine 3 di 3
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
  3. Backbone One Direction Pad Replacement, Remove the protective tape: passo 3, immagine 1 di 3 Backbone One Direction Pad Replacement, Remove the protective tape: passo 3, immagine 2 di 3 Backbone One Direction Pad Replacement, Remove the protective tape: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
  4. Backbone One Direction Pad Replacement, Open the ZIF connector: passo 4, immagine 1 di 2 Backbone One Direction Pad Replacement, Open the ZIF connector: passo 4, immagine 2 di 2
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
  5. Backbone One Direction Pad Replacement, Disconnect the interconnect cable: passo 5, immagine 1 di 2 Backbone One Direction Pad Replacement, Disconnect the interconnect cable: passo 5, immagine 2 di 2
    • Use your fingers to disconnect the interconnect cable from its connector.
  6. Backbone One Direction Pad Replacement: passo 6, immagine 1 di 2 Backbone One Direction Pad Replacement: passo 6, immagine 2 di 2
    • Remove the upper half of the left controller assembly.
  7. Backbone One Direction Pad Replacement, Remove the screw: passo 7, immagine 1 di 2 Backbone One Direction Pad Replacement, Remove the screw: passo 7, immagine 2 di 2
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
  8. Backbone One Direction Pad Replacement, Remove the trigger: passo 8, immagine 1 di 2 Backbone One Direction Pad Replacement, Remove the trigger: passo 8, immagine 2 di 2
    • Remove the left trigger.
  9. Backbone One Direction Pad Replacement, Remove the bumper: passo 9, immagine 1 di 2 Backbone One Direction Pad Replacement, Remove the bumper: passo 9, immagine 2 di 2
    • Use your fingers to remove the left bumper.
  10. Backbone One Direction Pad Replacement, Remove the screws: passo 10, immagine 1 di 1
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws.
  11. Backbone One Direction Pad Replacement, Remove the mainboard: passo 11, immagine 1 di 2 Backbone One Direction Pad Replacement, Remove the mainboard: passo 11, immagine 2 di 2
    • Remove the mainboard.
  12. Backbone One Direction Pad Replacement, Remove the direction pad: passo 12, immagine 1 di 3 Backbone One Direction Pad Replacement, Remove the direction pad: passo 12, immagine 2 di 3 Backbone One Direction Pad Replacement, Remove the direction pad: passo 12, immagine 3 di 3
    • Use a pair of blunt nose tweezers to remove the direction pad.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
Membro da: 12/18/19
66.478 Reputazione
167 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
25.562 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 70
Tutti i Tempi: 3,044
