Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Parti
Nessuna parte specificata.
  1. Take off the back by pulling on the tab near the top left of the back of the device. Take off the back by pulling on the tab near the top left of the back of the device.
    • Take off the back by pulling on the tab near the top left of the back of the device.
  2. Pull out the battery by pulling on the bottom left slit under the battery. Pull out the battery by pulling on the bottom left slit under the battery.
    • Pull out the battery by pulling on the bottom left slit under the battery.
  3. Take out the battery before unscrewing the screws. Take out the battery before unscrewing the screws.
    • Take out the battery before unscrewing the screws.
  4. Using the Phillips screwdriver bit size 000, unscrew out all 10 4.19mm screws.
    • Using the Phillips screwdriver bit size 000, unscrew out all 10 4.19mm screws.
  5. Use the iFixit Opening Tool to lift up the back, to disconnect the back with the inside of the device. Use the iFixit Opening Tool to lift up the back, to disconnect the back with the inside of the device. Use the iFixit Opening Tool to lift up the back, to disconnect the back with the inside of the device.
    • Use the iFixit Opening Tool to lift up the back, to disconnect the back with the inside of the device.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 128
