Introduzione
In order to access the components of your device, you will need to remove the back cover. This guide will help you accomplish this in a few simple steps.
Cosa ti serve
Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
Slide the opening tool to the right and slowly continue to separate the back cover from the device.
To reassemble your device, place the back cover in place and apply gentle pressure to snap the cover back on the device.
