Salta al contenuto principale
Baby Einstein Take Along Tunes Battery Socket Replacement
Cosa ti serve
  1. Baby Einstein Take Along Tunes Battery Socket Replacement, Battery Socket: passo 1, immagine 1 di 1
    • Set the device on it's face with the back facing up.
  2. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 2, immagine 1 di 1
    • Begin by removing all highlighted screws with a using a Phillips #1 Screwdriver.
  3. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 3, immagine 1 di 1
    • Remove the battery plate with a plastic opening tool and set it aside.
  4. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 4, immagine 1 di 1
    • Remove each battery with a plastic opening tool and set them aside.
  5. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 5, immagine 1 di 1
    • Separate the device in two parts by using the plastic opening tool.
  6. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 6, immagine 1 di 1
    • Remove the top piece and place it aside, keeping the bottom half with the mechanics.
  7. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 7, immagine 1 di 1
    • Remove the highlighted screws using a Phillips #1 Screwdriver.
  8. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 8, immagine 1 di 1
    • Use the plastic opening tool and carefully set the LED panel to the side, exposing the wires underneath.
  9. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • With the precision tweezers, straighten the metal connectors to remove the terminals from the other side.
  10. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 10, immagine 1 di 2 Baby Einstein Take Along Tunes Battery Socket Replacement: passo 10, immagine 2 di 2
    • Sever the red wire from the metal connector with the precision tweezers.
  11. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 11, immagine 1 di 2 Baby Einstein Take Along Tunes Battery Socket Replacement: passo 11, immagine 2 di 2
    • Sever the black wire from the metal connector with the precision tweezers.
  12. Baby Einstein Take Along Tunes Battery Socket Replacement: passo 12, immagine 1 di 2 Baby Einstein Take Along Tunes Battery Socket Replacement: passo 12, immagine 2 di 2
    • Flip the device on its face and remove the battery terminals with a metal spudger.
Conclusione
Shreya Sunny
Membro da: 09/04/15
607 Reputazione
6 Guide realizzate
USF Tampa, Team 2-2, Sullivan Fall 2015 Membro di USF Tampa, Team 2-2, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G2
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 30
Tutti i Tempi: 618
