Introduzione
Use this guide to replace the battery in your BUSY Bar or to remove it before disposing of the device.
Cosa ti serve
Use a plastic card to release one of the clips near the center at the bottom of the back cover.
Gently release the remaining clips until the back cover comes off completely.
Use a PH1 Phillips screwdriver to remove 1 screw from the bottom and 4 screws from the back of the device.
Use a plastic card to release the 2 latches on top of the front display.
Gently pull the front display unit out toward the right.
Gently move the battery to the left so you can access the connector.
Use tweezers or your fingertip to press the connector latch.
Pull the battery connector to disconnect it from the PCB.
