Introduzione
This guide will go over how to remove the two small speakers from the device.
Cosa ti serve
Remove the four 15.5 mm PH2 screws securing the base plate to the device.
Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
Remove the five 15.5 mm PH2 screws holding the motherboard down.
Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
Remove the motherboard.
Remove the eight 15.5 mm PH2 screws holding the plastic insert down.
Remove the plastic insert and set it to the side.
Altre 3 persone hanno completato questa guida.
