Salta al contenuto principale
BLV MGN Cube Klipper Neopixels Replacement
  1. BLV MGN Cube Klipper Neopixels Replacement, Wiring: passo 1, immagine 1 di 1
    • Wiring schematic
  2. BLV MGN Cube Klipper Neopixels Replacement, NeoPixel Setup Step 1: passo 2, immagine 1 di 2 BLV MGN Cube Klipper Neopixels Replacement, NeoPixel Setup Step 1: passo 2, immagine 2 di 2
    • Thanks to Pawel Drylenko we now have a working solution to incorporate the Arduino Neopixels with Klipper. We're created shell scripts to make installation easier. SSH into the RPI. Run the following commands:
    • git clone https://github.com/armysolo/neopixels_in...
    • cd into the newly created "neopixels_install" directory
    • cd neopixels_install/
    • Run the script for step 1
    • sh neopixel_step_1.sh
    • When prompted reboot the pi
    • SSH back into the RPI. Run the following commands
    • cd into the "neopixels_install" directory
    • Run the script for step 2
    • sh neopixel_step_2.sh
    • when prompted enter password for sudo
  3. BLV MGN Cube Klipper Neopixels Replacement, NeoPixel Setup Step 3: passo 4, immagine 1 di 1
    • Run the script for step 3
    • sh neopixel_step_3.sh
    • You'll need to enter your sudo password twice
    • If you have your NeoPixels already wired you should see them light up
Linea Traguardo
Altre 2 persone hanno completato questa guida.
David Husolo
Membro da: 06/16/21
9.132 Reputazione
33 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,003
