Salta al contenuto principale
BLU WIN HD LTE Frame Cover Replacement
Cosa ti serve
  1. BLU WIN HD LTE Frame Cover Replacement, Back Case: passo 1, immagine 1 di 1
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Frame Cover Replacement: passo 2, immagine 1 di 1
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Frame Cover Replacement, Frame Cover: passo 3, immagine 1 di 1
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Frame Cover Replacement: passo 4, immagine 1 di 1
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
Conclusione
To reassemble your device, follow these instructions in reverse order. Ensure that all sides of the frame cover are firmly snapped on before replacing the screws.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 182
