Salta al contenuto principale
BLU WIN HD LTE Camera Replacement
Cosa ti serve
  1. BLU WIN HD LTE Camera Replacement, Back Case: passo 1, immagine 1 di 1
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Camera Replacement: passo 2, immagine 1 di 1
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Camera Replacement, Frame Cover: passo 3, immagine 1 di 1
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Camera Replacement: passo 4, immagine 1 di 1
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
  5. BLU WIN HD LTE Camera Replacement, Camera: passo 5, immagine 1 di 3 BLU WIN HD LTE Camera Replacement, Camera: passo 5, immagine 2 di 3 BLU WIN HD LTE Camera Replacement, Camera: passo 5, immagine 3 di 3
    • Pry off the low profile connector located on the right side of the camera device.
  6. BLU WIN HD LTE Camera Replacement: passo 6, immagine 1 di 1
    • Pull the camera out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 290
