Salta al contenuto principale
BLU WIN HD LTE Battery Replacement
Cosa ti serve
  1. BLU WIN HD LTE Battery Replacement, Back Case: passo 1, immagine 1 di 1
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Battery Replacement: passo 2, immagine 1 di 1
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Battery Replacement, Frame Cover: passo 3, immagine 1 di 1
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Battery Replacement: passo 4, immagine 1 di 1
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
  5. BLU WIN HD LTE Battery Replacement, Battery: passo 5, immagine 1 di 2 BLU WIN HD LTE Battery Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the battery out using the black nylon spudger.
    • Battery is secured by glue so use more force to take it out.
Conclusione
2 Commenti
I replaced the battery but now there is a symbol on the screen, box with a question mark, what does that mean?
raybrooks - Replica
I hope someone else has had this issue an has a solution. Thank you in advance for any and all help.
raybrooks - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 650
