Salta al contenuto principale
BLU Vivo 5 Mini Camera Replacement
Cosa ti serve
  1. BLU Vivo 5 Mini Camera Replacement, Back Cover: passo 1, immagine 1 di 3 BLU Vivo 5 Mini Camera Replacement, Back Cover: passo 1, immagine 2 di 3 BLU Vivo 5 Mini Camera Replacement, Back Cover: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the 2 screws along the bottom on either side of the speaker port with the size 2 Pentalobe driver.
    • After screws are removed, dislodge the speaker and charger port cover from device using the tweezers.
  2. BLU Vivo 5 Mini Camera Replacement: passo 2, immagine 1 di 3 BLU Vivo 5 Mini Camera Replacement: passo 2, immagine 2 di 3 BLU Vivo 5 Mini Camera Replacement: passo 2, immagine 3 di 3
    • Remove the top and bottom covers.
    • Start by sliding the pick around the edges of both covers. (If you have the glue adhesive removal tool use that instead of pick, as it creates less damage.)
    • After freeing the edges gentle start peeling the covers off.
  3. BLU Vivo 5 Mini Camera Replacement: passo 3, immagine 1 di 3 BLU Vivo 5 Mini Camera Replacement: passo 3, immagine 2 di 3 BLU Vivo 5 Mini Camera Replacement: passo 3, immagine 3 di 3
    • Using a Phillips #000, remove all 10 screws found on the back of the phone.
    • The 6 on the bottom are to be removed with a size PH000 Phillips Head screwdriver.
    • The 4 on the top can be removed with the same screwdriver.
  4. BLU Vivo 5 Mini Camera Replacement: passo 4, immagine 1 di 3 BLU Vivo 5 Mini Camera Replacement: passo 4, immagine 2 di 3 BLU Vivo 5 Mini Camera Replacement: passo 4, immagine 3 di 3
    • Completely remove SIM card port from side of phone using the SIM Card Eject Tool.
    • Release the back cover (it may be glued down encasing the phone) using the suction device to lift the back off.
    • Begin inserting the pick sliding it between the back of the phone and the cover to completely remove back cover, if suction does not lift.
  5. BLU Vivo 5 Mini Camera Replacement, Camera: passo 5, immagine 1 di 1
    Compra
    • Using tweezers, remove the top black encasing of the camera.
  6. BLU Vivo 5 Mini Camera Replacement: passo 6, immagine 1 di 3 BLU Vivo 5 Mini Camera Replacement: passo 6, immagine 2 di 3 BLU Vivo 5 Mini Camera Replacement: passo 6, immagine 3 di 3
    • Using the tweezers unlink the camera gently from the gold wire
  7. BLU Vivo 5 Mini Camera Replacement: passo 7, immagine 1 di 2 BLU Vivo 5 Mini Camera Replacement: passo 7, immagine 2 di 2
    • Gently lift the back camera from the phone.
    • Be careful not to smudge the lens. At this time, also check for debris.
  8. BLU Vivo 5 Mini Camera Replacement: passo 8, immagine 1 di 3 BLU Vivo 5 Mini Camera Replacement: passo 8, immagine 2 di 3 BLU Vivo 5 Mini Camera Replacement: passo 8, immagine 3 di 3
    • Use the spudger to gently lift the motherboard out of the device.
    • After completely removing the back camera and motherboard, now check underneath for debris near front lens.
    • Front lens can now be removed for replacement.
Conclusione
Kymari
Membro da: 10/09/18
725 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 226
