Introduzione
This guide will detail how to remove and replace the outer lens of the camera of the BLU Tank II cell phone. The guide will require knowledge from the previous guides in order to successfully replace the lens. This guide requires a screwdriver and an opening tool.
Cosa ti serve
With the screen facing you, find the left corner of the phone. There should be a visible groove.
With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
Lift the battery up and carefully remove the battery.
Locate the two 2.5mm screws (red circles in image) and remove them with the Philips 00 screwdriver used previously.
Once separated from the motherboard, the outer lens can now be replaced.
