Salta al contenuto principale
BLU Tank II Keypad Replacement
Cosa ti serve
  1. BLU Tank II Keypad Replacement, Back Panel: passo 1, immagine 1 di 2 BLU Tank II Keypad Replacement, Back Panel: passo 1, immagine 2 di 2
    • With the screen facing you, find the left corner of the phone. There should be a visible groove.
    • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
  2. BLU Tank II Keypad Replacement, Battery: passo 2, immagine 1 di 1
    • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
    • Lift the battery up and carefully remove the battery.
  3. BLU Tank II Keypad Replacement, Front Panel: passo 3, immagine 1 di 2 BLU Tank II Keypad Replacement, Front Panel: passo 3, immagine 2 di 2
    • Using the phillips head screwdriver, remove all 5 2.5mm screws.
  4. BLU Tank II Keypad Replacement: passo 4, immagine 1 di 1
    • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
    • Carefully separate the front plate from all sides of the phone.
  5. BLU Tank II Keypad Replacement, Keypad: passo 5, immagine 1 di 3 BLU Tank II Keypad Replacement, Keypad: passo 5, immagine 2 di 3 BLU Tank II Keypad Replacement, Keypad: passo 5, immagine 3 di 3
    • Once the front plate is separated from the outer lens plate, place your fingers on the backside of the keypad.
    • Peel the keypad out from the keyholes in the front plate.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 147
