Salta al contenuto principale
BLU Studio G Battery Replacement
Cosa ti serve
  1. BLU Studio G Battery Replacement, Battery: passo 1, immagine 1 di 3 BLU Studio G Battery Replacement, Battery: passo 1, immagine 2 di 3 BLU Studio G Battery Replacement, Battery: passo 1, immagine 3 di 3
    • To remove the back cover, locate the safety indented notch on the bottom left corner as the screen is facing down.
    • Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
    • Set back cover aside.
  2. BLU Studio G Battery Replacement: passo 2, immagine 1 di 2 BLU Studio G Battery Replacement: passo 2, immagine 2 di 2
    • Locate the notch at the bottom of the battery for safe removal.
    • Carefully lift battery from the notch making sure not to puncture the battery rubber casting.
    • Set battery aside and insert new one .
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 344
