Salta al contenuto principale
BLU Studio 7.0 II Back Cover Replacement
Cosa ti serve
  1. BLU Studio 7.0 II Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Locate the seam between the black and silver pieces of the phone.
    • Insert a plastic opening tool into the seam and firmly pry the black back piece away from the silver front piece.
    • To create the initial separation for the plastic opening tool, you may need to use either a spudger or metal spudger. If you use a metal spudger, be aware this can damage your phone if you aren't careful.
  2. BLU Studio 7.0 II Back Cover Replacement: passo 2, immagine 1 di 1
    • Work your way around the edge of phone, firmly prying the pieces apart.
  3. BLU Studio 7.0 II Back Cover Replacement: passo 3, immagine 1 di 2 BLU Studio 7.0 II Back Cover Replacement: passo 3, immagine 2 di 2
    • Once the back has been removed, you can snap the new one into place by pressing firmly around the edges with your fingers.
Linea Traguardo
Altre 5 persone hanno completato questa guida.
Abby
Membro da: 05/14/16
852 Reputazione
5 Guide realizzate
Metro State, Team 1-2, Carpenter SU 2016 Membro di Metro State, Team 1-2, Carpenter SU 2016
MSU-CARPENTER-SU16S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,132
