Salta al contenuto principale
BLU Studio 5.0 S II Speaker Replacement
Cosa ti serve
  1. BLU Studio 5.0 S II Speaker Replacement, Remove back cover.: passo 1, immagine 1 di 1
    • Remove the back cover on the phone with the plastic opening tool.
  2. BLU Studio 5.0 S II Speaker Replacement, Remove battery: passo 2, immagine 1 di 1
    • Remove battery with plastic opening tool.
  3. BLU Studio 5.0 S II Speaker Replacement, Remove screws: passo 3, immagine 1 di 1
    • On the bottom part of the back of the phone with a Phillips screwdriver #00 tool remove the 6 screws that hold the speaker in place.
  4. BLU Studio 5.0 S II Speaker Replacement, Remove speaker plastic backing: passo 4, immagine 1 di 1
    • After removing screws gently pull off the speaker from the back of the phone.
  5. BLU Studio 5.0 S II Speaker Replacement, Remove speaker.: passo 5, immagine 1 di 1
    • Remove the speaker from the backing of the speaker holder.
  6. BLU Studio 5.0 S II Speaker Replacement, Replace speaker.: passo 6, immagine 1 di 1
    • Replace the old speaker with a new speaker. Put it back in where the old speaker was.
  7. BLU Studio 5.0 S II Speaker Replacement, Put the screws back on: passo 7, immagine 1 di 1
    • Insert the plastic backing of the speaker back in the phone.
    • Put the six screws back in the backing of the phone to hold the plastic backing securely.
Conclusione
Altre 2 persone hanno completato questa guida.
Gateway, Team 1-3, Johnson Fall 2014 Membro di Gateway, Team 1-3, Johnson Fall 2014
GCC-JOHNSON-F14S1G3
3 Membri
5 Guide realizzate
2 Commenti
Excellent instruction! Great pictures as well! Well done+!
Kelly - Replica
Can you upload a guide on how to replace this device's screen? Pretty much appreciated.
Moe Ojeda - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,637
