Introduzione
This guide will show you how to successfully remove the motherboard from your BLU Studio 5.0 II.
Cosa ti serve
Locate the four 3mm screws on each side of the back panel.
Use a Phillips #00 screwdriver to remove the eight screws.
Locate the following adhesive buttons on the right and left side of the motherboard. These are the volume and power buttons.
Use a spudger to carefully separate them from the circuit board.
Altre 2 persone hanno completato questa guida.
