Salta al contenuto principale
Introduzione
This replacement guide will teach you how to successfully remove the back casing on your BLU Studio 5.0 II phone.
Parti
Nessuna parte specificata.
  1. Turn off your phone before disassembling the device.
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. Use your finger to open the back case by slowly pulling it on the open slot. Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  3. Batterie per PC portatili
    Batteries for all the top PC brands, backed by our Quality Guarantee.
    Acquista ora
    Acquista ora
  4. Locate the opening slot at the bottom of the battery. Use your finger to lift the battery and remove it from the case. Use your finger to lift the battery and remove it from the case.
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
  5. Locate the four 3mm screws on each side of the back panel.
    • Locate the four 3mm screws on each side of the back panel.
    • Use a Phillips #00 screwdriver to remove the eight screws.
  6. Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone. With the help of your fingers, continue to remove the back case by sliding it through the opening. With the help of your fingers, continue to remove the back case by sliding it through the opening.
    • Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone.
    • With the help of your fingers, continue to remove the back case by sliding it through the opening.
Conclusione
Ricardo Sarabia
Membro da: 09/02/2016
1.030 Reputazione
6 Guide realizzate
USF Tampa, Team 7-5, Cheng Spring 2016 Membro di USF Tampa, Team 7-5, Cheng Spring 2016
USFT-CHENG-S16S7G5
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 274
