Salta al contenuto principale
BLU Life XL Speaker Replacement
Cosa ti serve
  1. BLU Life XL Speaker Replacement, Speaker: passo 1, immagine 1 di 3 BLU Life XL Speaker Replacement, Speaker: passo 1, immagine 2 di 3 BLU Life XL Speaker Replacement, Speaker: passo 1, immagine 3 di 3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Speaker Replacement: passo 2, immagine 1 di 2 BLU Life XL Speaker Replacement: passo 2, immagine 2 di 2
    • Remove twelve 2.1mm Phillips #000 screws from the rear plate.
  3. BLU Life XL Speaker Replacement: passo 3, immagine 1 di 2 BLU Life XL Speaker Replacement: passo 3, immagine 2 di 2
    • Use an opening tool to separate the rear plate from the phone.
    • Firmly press the opening tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • If the opening tool is not working, try using your fingernails on the side of the phone. Once a small area of the rear plate is released, continue to use the opening tool.
    • Run the opening tool around the entire phone separating the rear plate from the frame.
  4. BLU Life XL Speaker Replacement: passo 4, immagine 1 di 3 BLU Life XL Speaker Replacement: passo 4, immagine 2 di 3 BLU Life XL Speaker Replacement: passo 4, immagine 3 di 3
    • Gently flip the tan cable lock back to release the ribbon cable from the lower PCB Board.
    • Using a spudger, gently pull the ribbon cable from its socket.
    • Remove the 3mm screw from the PCB using a Phillips #000 screwdriver.
  5. BLU Life XL Speaker Replacement: passo 5, immagine 1 di 3 BLU Life XL Speaker Replacement: passo 5, immagine 2 di 3 BLU Life XL Speaker Replacement: passo 5, immagine 3 di 3
    • Locate the speaker and connected haptic motor on the lower PCB of the phone.
    • Using an opening tool, lightly pry around all edges of the PCB until it releases from the adhesive backing.
    • Use the same process as above to remove the Haptic motor. It has the black and red wire connected to it and the PCB.
Linea Traguardo
James Whitlow
Membro da: 02/14/18
342 Reputazione
3 Guide realizzate
USF Tampa, Team S2-G5, Eyestone Spring 2018 Membro di USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 303
