Salta al contenuto principale
BLU Life XL Charging Port Replacement
Cosa ti serve
  1. BLU Life XL Charging Port Replacement, Battery: passo 1, immagine 1 di 3 BLU Life XL Charging Port Replacement, Battery: passo 1, immagine 2 di 3 BLU Life XL Charging Port Replacement, Battery: passo 1, immagine 3 di 3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
  2. BLU Life XL Charging Port Replacement: passo 2, immagine 1 di 3 BLU Life XL Charging Port Replacement: passo 2, immagine 2 di 3 BLU Life XL Charging Port Replacement: passo 2, immagine 3 di 3
    • Remove the old battery.
    • For optimal performance, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
  3. BLU Life XL Charging Port Replacement, Charging Port: passo 3, immagine 1 di 2 BLU Life XL Charging Port Replacement, Charging Port: passo 3, immagine 2 di 2
    • Remove twelve 3mm Phillips #000 screws from the rear plate.
  4. BLU Life XL Charging Port Replacement: passo 4, immagine 1 di 2 BLU Life XL Charging Port Replacement: passo 4, immagine 2 di 2
    • Remove the plastic frame on the device using an opening tool.
    • Firmly press the tool into the gap between the front glass and rear plate.
    • The gap is located on all sides of the phone.
    • Run the tool through this gap along the entire edge of the phone to separate the plastic frame from the phone.
  5. BLU Life XL Charging Port Replacement: passo 5, immagine 1 di 3 BLU Life XL Charging Port Replacement: passo 5, immagine 2 di 3 BLU Life XL Charging Port Replacement: passo 5, immagine 3 di 3
    • Disconnect lower PCB antenna connection.
    • Disconnect lower PCB data cable connection.
    • Remove the single JIS #000 3mm screw from the PCB board.
  6. BLU Life XL Charging Port Replacement: passo 6, immagine 1 di 1
    • Remove the haptic motor at bottom left of the device. This will require a prying tool, as the motor is glued to the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Euan Gordon
Membro da: 02/14/18
164 Reputazione
1 Guida realizzata
USF Tampa, Team S2-G5, Eyestone Spring 2018 Membro di USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,134
