Salta al contenuto principale
BLU Dash 3.5 Screen Assembly Replacement
Cosa ti serve
  1. BLU Dash 3.5 Screen Assembly Replacement, Battery: passo 1, immagine 1 di 3 BLU Dash 3.5 Screen Assembly Replacement, Battery: passo 1, immagine 2 di 3 BLU Dash 3.5 Screen Assembly Replacement, Battery: passo 1, immagine 3 di 3
    • Start by locating the slot on the lower right corner of the device.
    • Insert the opening tool into the slot.
    • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
    • A fingernail can work to open the back in place of an opening tool.
  2. BLU Dash 3.5 Screen Assembly Replacement: passo 2, immagine 1 di 2 BLU Dash 3.5 Screen Assembly Replacement: passo 2, immagine 2 di 2
    • Locate the indentation at the bottom of the battery.
    • Insert your thumb and pull the battery out.
  3. BLU Dash 3.5 Screen Assembly Replacement, Volume and Lock Button: passo 3, immagine 1 di 2 BLU Dash 3.5 Screen Assembly Replacement, Volume and Lock Button: passo 3, immagine 2 di 2
    • Use the 000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
    • Use the opening tool to pry open the plastic back panel to expose the motherboard.
  4. BLU Dash 3.5 Screen Assembly Replacement: passo 4, immagine 1 di 2 BLU Dash 3.5 Screen Assembly Replacement: passo 4, immagine 2 di 2
    • Remove volume and lock buttons by lifting them gently from the casing.
  5. BLU Dash 3.5 Screen Assembly Replacement, Screen Assembly: passo 5, immagine 1 di 2 BLU Dash 3.5 Screen Assembly Replacement, Screen Assembly: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to lift the tab where the cable is connected.
    • Use the opening tool to pry the motherboard from the front face plate.
  6. BLU Dash 3.5 Screen Assembly Replacement: passo 6, immagine 1 di 2 BLU Dash 3.5 Screen Assembly Replacement: passo 6, immagine 2 di 2
    • Use opening tool to pry off the screen.
    • Use a soldering tool to melt the contact between the motherboard and the screen
    • Solder new screen contacts to the motherboard.
Conclusione
Jeffrey Dlugosz
Membro da: 09/29/15
104 Reputazione
1 Guida realizzata
Ohio State, Team 1-2, Garvin Fall 2015 Membro di Ohio State, Team 1-2, Garvin Fall 2015
OSU-GARVIN-F15S1G2
4 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 709
