Salta al contenuto principale
BLU Advance 4.0 Screen Replacement
Cosa ti serve
  1. Attenzione: i passaggi 1-3 provengono da una guida contrassegnata come in corso.
    BLU Advance 4.0 Screen Replacement, Removing the back cover: passo 1, immagine 1 di 2 BLU Advance 4.0 Screen Replacement, Removing the back cover: passo 1, immagine 2 di 2
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
  2. BLU Advance 4.0 Screen Replacement, Revealing the motherboard: passo 2, immagine 1 di 3 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: passo 2, immagine 2 di 3 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: passo 2, immagine 3 di 3
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. BLU Advance 4.0 Screen Replacement, Separating motherboard from screen: passo 3, immagine 1 di 1
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
Conclusione
Altre 5 persone hanno completato questa guida.
Jon Sclar
Membro da: 11/13/14
292 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,302
