Salta al contenuto principale
BLU Advance 4.0 Rear Case Disassembly
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. BLU Advance 4.0 Rear Case Disassembly, Removing the back cover: passo 1, immagine 1 di 2 BLU Advance 4.0 Rear Case Disassembly, Removing the back cover: passo 1, immagine 2 di 2
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
  2. BLU Advance 4.0 Rear Case Disassembly, Revealing the motherboard: passo 2, immagine 1 di 3 BLU Advance 4.0 Rear Case Disassembly, Revealing the motherboard: passo 2, immagine 2 di 3 BLU Advance 4.0 Rear Case Disassembly, Revealing the motherboard: passo 2, immagine 3 di 3
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. BLU Advance 4.0 Rear Case Disassembly, Separating motherboard from screen: passo 3, immagine 1 di 1
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
Conclusione
David Okide
Membro da: 10/19/14
14 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 21
Tutti i Tempi: 8,375
