Salta al contenuto principale
Introduzione
When replacing the speaker motherboard is important to use this as a last resort if your speaker is not turning on. The buttons could be not functioning and that would be a problem with the charging base motherboard or simply cleaning the buttons. The reason to replace the speaker motherboard would be if the ON/OFF switch is broken and not working at all. This guide will show you how to replace the speaker motherboard.
  1. Pull back the rubber corners to uncover the bottom  screws.
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
  2. Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
  3. Remove the bottom cover of the speaker.
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
  4. Kit per Apple Watch
    Screen and battery repairs just got easier.
    Acquista ora
    Kit per Apple Watch
    Acquista ora
  5. Remove the speakers battery from its metal base, utilizing the plastic opening tool.
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
  6. Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
  7. Use the J0 screwdriver to remove all four 10mm screws from the motherboard.
    • Use the J0 screwdriver to remove all four 10mm screws from the motherboard.
  8. Remove the red/black wires in addition to the blue/white wires using the tweezers.
    • Remove the red/black wires in addition to the blue/white wires using the tweezers.
  9. Remove bus wire from the speaker's motherboard and lift the motherboard out of the speaker.
    • Remove bus wire from the speaker's motherboard and lift the motherboard out of the speaker.
Conclusione
Rachel Iacoboni
Membro da: 30/01/2018
567 Reputazione
5 Guide realizzate
Baylor, Team S1-G1, Johnson Spring 2018 Membro di Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 77
