Salta al contenuto principale
BEM Mojo 2 Charging Base Battery Replacement
Cosa ti serve
  1. BEM Mojo 2 Charging Base Battery Replacement, Charging Base Battery: passo 1, immagine 1 di 1
    • Use the metal spudger to peel back the rubber from the bottom of the auxiliary charging base to reveal the screw.
  2. BEM Mojo 2 Charging Base Battery Replacement: passo 2, immagine 1 di 1
    • Use the screwdriver with the J0 bit attatched to detach all four 10 mm screws from the charging base.
  3. BEM Mojo 2 Charging Base Battery Replacement: passo 3, immagine 1 di 2 BEM Mojo 2 Charging Base Battery Replacement: passo 3, immagine 2 di 2
    • Pull the top cover off of the charging base to reveal the internal chip.
    • Use the plastic opening tool to pry the battery from the top cover.
    • Caution: Be careful when detaching battery from top cover as to not damage any of the wires attached to it.
  4. BEM Mojo 2 Charging Base Battery Replacement: passo 4, immagine 1 di 1
    • Use the tweezers to carefully detach the wires from the internal chip.
    • Caution: Be careful to not damage the internal chip when removing the wires.
Conclusione
Baylor, Team S1-G1, Johnson Spring 2018 Membro di Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 392
