Salta al contenuto principale
BELLA TXG-DS14 Heating Plate Replacement
Cosa ti serve
  1. BELLA TXG-DS14 Heating Plate Replacement, Heating Plate: passo 1, immagine 1 di 2 BELLA TXG-DS14 Heating Plate Replacement, Heating Plate: passo 1, immagine 2 di 2
    • Turn the device off and make sure it is cooled down. Then place the device in front of you and take the drawer out by placing a hand on the handle and pull towards you. Make sure the plug is out of the way before starting any of the following steps.
    • Slide the clear lock away from the button and press down on the release button to release the basket from the drawer.
  2. BELLA TXG-DS14 Heating Plate Replacement: passo 2, immagine 1 di 2 BELLA TXG-DS14 Heating Plate Replacement: passo 2, immagine 2 di 2
    • Turn the device onto its side and have the bottom surface face you.
    • Remove the 1.5 mm Phillips #1 screws from the bottom of the device. Rotate the screws counterclockwise with a Phillip's #1 screwdriver.
    • There should be 8 screws removed by the end of this step
    • Make sure to keep the screws in a safe spot
  3. BELLA TXG-DS14 Heating Plate Replacement: passo 3, immagine 1 di 3 BELLA TXG-DS14 Heating Plate Replacement: passo 3, immagine 2 di 3 BELLA TXG-DS14 Heating Plate Replacement: passo 3, immagine 3 di 3
    • Place the unscrewed bottom cover next to the device without damaging the cords by extending them.
    • Unscrew all the 1.2mm Phillip's #1 screw around the silver plate by rotating them counterclockwise with Phillip's #1 screwdriver to take the plate off.
    • There should be 6 screws removed by the end of this device
  4. BELLA TXG-DS14 Heating Plate Replacement: passo 4, immagine 1 di 2 BELLA TXG-DS14 Heating Plate Replacement: passo 4, immagine 2 di 2
    • Locate 8 silver holds that holds the silver plate and black cover together.
    • Use a 0.1mm Flathead screwdriver to bend the 8 silver folds toward the center of the circle to release the silver plate.
    • Be careful to not cut yourself on the sharp edges of the silver folds.
  5. BELLA TXG-DS14 Heating Plate Replacement: passo 5, immagine 1 di 1
    • Remove the silver heating plate and install the new one.
    • Fold the silver edges back into place and put the screws back in. For further reassembly , follow this guide in reverse order.
    • When installing the new silver heating plate, make sure to not over bend the silver edges as they can easily break.
Conclusione
UC Davis, Team S7-G6, Lore Fall 2018 Membro di UC Davis, Team S7-G6, Lore Fall 2018
UCD-LORE-F18S7G6
3 Membri
2 Guide realizzate
Un commento
Bella 1.6 txg-af15a
Basket and Drawers
Reinaldo Figueroa - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 46
Tutti i Tempi: 1,863
