Salta al contenuto principale
Azpen A740 Battery Replacement
Cosa ti serve
  1. Azpen A740 Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
  2. Azpen A740 Battery Replacement, Battery: passo 2, immagine 1 di 2 Azpen A740 Battery Replacement, Battery: passo 2, immagine 2 di 2
    • Use the set of plastic opening tools to separate the inner backing from the electronics.
    • Use the Phillips screwdriver to remove the 3.8 mm screws, holding the inner backing of Azpen A740 Tablet.
  3. Azpen A740 Battery Replacement: passo 3, immagine 1 di 1
    • Disconnect the black, red, and grey wires leading to the battery from the motherboard using a soldering iron.
    • In order to desolder these connections follow the instructions on IFixit's How to Solder and Desolder Connections
  4. Azpen A740 Battery Replacement: passo 4, immagine 1 di 2 Azpen A740 Battery Replacement: passo 4, immagine 2 di 2
    • Remove the black tape that is holding the battery in place.
  5. Azpen A740 Battery Replacement: passo 5, immagine 1 di 1
    • Remove the battery from the case using the blue prying or black spudger.
    • As you remove the battery it may be difficult to remove. Take your time to remove it carefully and try to avoid bending it.
Conclusione
USF Tampa, Team 4-5, Brown Winter 2015 Membro di USF Tampa, Team 4-5, Brown Winter 2015
USFT-BROWN-W15S4G5
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,589
