Introduzione
The screen assembly is located underneath all of the other parts of the device. To access it, you will have to remove these pieces first. Make sure to keep track of all five screws and any connected parts.
Cosa ti serve
Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
Disconnect the two largest (of the three) ZIF cables by prying open the flap with a plastic spudger to gently remove them.
