Salta al contenuto principale
Azpen A701 General Disassembly Prerequisite Guide Replacement
Cosa ti serve
  1. Azpen A701 General Disassembly Prerequisite Guide Replacement, General Disassembly Prerequisite Guide: passo 1, immagine 1 di 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 General Disassembly Prerequisite Guide Replacement: passo 2, immagine 1 di 2 Azpen A701 General Disassembly Prerequisite Guide Replacement: passo 2, immagine 2 di 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 General Disassembly Prerequisite Guide Replacement: passo 3, immagine 1 di 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 General Disassembly Prerequisite Guide Replacement: passo 4, immagine 1 di 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
Conclusione
Michael
Membro da: 03/11/15
568 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 390
