Salta al contenuto principale
Axess TA2513-10WT Side Button Replacement
Cosa ti serve
  1. Axess TA2513-10WT Side Button Replacement, Back Cover: passo 1, immagine 1 di 1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Side Button Replacement: passo 2, immagine 1 di 3 Axess TA2513-10WT Side Button Replacement: passo 2, immagine 2 di 3 Axess TA2513-10WT Side Button Replacement: passo 2, immagine 3 di 3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Side Button Replacement: passo 3, immagine 1 di 1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Side Button Replacement: passo 4, immagine 1 di 1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Side Button Replacement, Buttons: passo 5, immagine 1 di 2 Axess TA2513-10WT Side Button Replacement, Buttons: passo 5, immagine 2 di 2
    • Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
  6. Axess TA2513-10WT Side Button Replacement: passo 6, immagine 1 di 2 Axess TA2513-10WT Side Button Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Unlatch the clear rubber holder from the posts with the tweezers.
  7. Axess TA2513-10WT Side Button Replacement: passo 7, immagine 1 di 2 Axess TA2513-10WT Side Button Replacement: passo 7, immagine 2 di 2
    • With tweezers, pull the rubber holder from the back cover completely.
  8. Axess TA2513-10WT Side Button Replacement: passo 8, immagine 1 di 3 Axess TA2513-10WT Side Button Replacement: passo 8, immagine 2 di 3 Axess TA2513-10WT Side Button Replacement: passo 8, immagine 3 di 3
    • Remove the individual buttons with tweezers.
Conclusione
Lori Scott
Membro da: 03/24/15
101 Reputazione
1 Guida realizzata
Baylor, Team 6-3, Shaver Spring 2015 Membro di Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 334
