Introduzione
This guide shows how to replace Axess SPBT1031 Subwoofer. Replacing the subwoofer is moderate difficulty and it'll take about 15 minutes to replace. Below is the step-by-step guide to replacing the subwoofer.
Cosa ti serve
Look at the side of the speaker without the red interface plate; there will be a red ring around the mesh but no buttons on the side.
Remove the two 5.5 mm screws from the top and bottom of the black face plate using a Phillips #1 screwdriver.
Attrezzo utilizzato in questo passaggio:Desoldering Pump$3.99
Use a desoldering pump to remove the liquid solder from the terminals.
Altre 2 persone hanno completato questa guida.
Un commento
I Ned to replace the charger conection and I need the parts please u can email me at elpaleterolopez@Gmail.com or call me at 6613402547
